Peaps, you've misread my posts.
I was replying to someone elses suggestion of taping up . Interesting that you didn't jump in there, when you must have seen that as bad advice too..... ........
What I said was IF taping up, then you should put it on straight - which is not easy - and it is YOU who has the responsibilty for the tape if you want it there, not the plasterer - it may peel off paint, you may have plaster gathering etc
This is pointing out why taping up is not always good -
"Your tape may be too high, and then the plaster will go over it , or too low meaning you will have some plaster on the wall which will be doubly hard to clean as it gathers between in the little gap between tape and ceiling."
Obviously no one should do any prepping without consulting the tradesman engaged.
Of course I accept that you have limited experience in plastering ceilings in cases where the paint can be affected by the moisture etc, that's just down to the type of work you have done and is not your fault.
Likewise, you have never applied render by machine and had to tape up to protect - again not your fault, just an experience you haven't had yet.
