Plumbing gods,
Today I replaced a faulty PRV with a one from screwfix it is this one
http://www.screwfix.com/p/prv-with-gauge-15-x-22mm/41943
went on a doddle however the pressure gauge is not reading?
There is a TMV fitted after it and I noticed that after you draw off some water, the TMV outlet becomes cold very quickly as though the mains cold is pushing through (does this make sense) This did not happen with the older PRV
The cold is mains and the hot is gravity from a hot water tank. I have tried reducing pressure as much as possible but this still happens. And it also appears to stall at the taps. You turn them on and some comes out then it stalls to a drip then normal service resumes, quite annoying really
any advice please?
any advice please?
