Hey guys
We moved into a new house last august with an old system
Its gravity fed open vented system with feed and expansion tank in the loft.A hot water cylinder upstairs.The boiler is an old glow worm balanced flue model.
There is a water pump under the floor boards near the boiler that was replaced just before we moved in.
The system was full of black gunk and the radiator bleed valves were painted over and had not been bled for years.I have emptied the system and flushed out the radiators with a hose to clean them.
The hallway in the hallway never worked since we moved in and i thought by cleaning out the radiators this would fix it but it didnt.
I managed to get at the pump and as this had been replaced i thought it may have been fitted incorrectly so reversed it.This caused the heating not to work although the hot water still does and a wet patch appeared on a interior wall at the front of the house.
I have reversed it back but the heating still doesnt work even though the hot water does.
The Boiler when switched on stays on for 5 mins then cuts out.
The pump seems to work as when you change the speed you can hear a difference.
Any help would be appreciated
I have attached photos of some of my system
