Hi all,
I'm in the middle of planning a home office shed and have a family friend who is a part-p certified electrician so I'm going to be asking him for a quote.
I really just wanted to make sure I know what everything entails. Could someone with experience check my understanding below and correct me if I'm wrong?
From what I understand, the electrician will add a new fuse to our existing fusebox, and take that through the house, out into the garden (using SWA cable) and down to the back of the shed, where it will go into another consumer unit of some sort, correct? (Sorry if my terminology is completely wrong!)
The issue I'm thinking of is that the consumer unit is in a downstairs toilet, at the front of our house. Between that and the garden there is a brick wall (to the garage), a stud wall and then two more brick walls before hitting outside. We've not got a big house, or a big garden, but I'm just concerned that I may be told it cant be done due to not being able to practically get a wire down there.
Another problem is that the lower half of the garden is completely paved, and these cant be lifted up to burry a cable. Can it effectively be 'tucked' down the side of the paved area where it meets the fence, or would it need to be run somewhere else?
A final option was another route. We've got a passage way down the other side of our house, and we've got about 50cm of grass with bushes running down the side, to our back gate. It could go this way, but it would mean running it all the way around the garden...surely this would cause a massive voltage drop?
I've put a (rather crude) drawing together showing what I mean, with, what I would have thought is the best route.
Any advice or info would be appreciated.
Thanks,
Rick
Thanks,
Rick
