Finally finished laying 80m2 of Marshalls Woodstone paving on a mortar bed (3:1.5:1 sharp:building:cement) and its time to point. Due to the irregularity in this paving, the gaps vary between 2mm and 8mm. Seeing as this paving is extensively textured, brushing a dry-mix (or slurry for that matter) isn't an option. So, I see the options are:
1. Painstakingly trowel using a 4:1 building sand mix (with some plasticiser to help things along a tad). High risk of staining as the edges of every slab are different and in some cases stagger downwards.
2. Use a point gun with above mix. I haven't ever used a gun as they seem to get very mixed reviews, but might be just the ticket here.
3. Trowel using a dry polymeric sand. Probably the fastest method and zero risk of staining, but are these sands as good as using a standard mortar in terms of durability?
How would you guys go about pointing this type of paving?
Picture of paving (from Marshalls marketing material):
