Damp wall help...
13 Feb 2008
I need to find out how to sort this wall out, it looks like it has quite a bad damp problem.
The wall is probably 4ft below ground level (as we have a sloping hill garden). The plaster has blown quite badly, however then brickwork behind look quite ok.
I need to get this sorted so I can then plaster it and make it good for a utility room.
Can anyone advise if this is easily down, for example, can i just rip off the old plaster, blast dry the room, paint it with some damp proof chemical then plaster it or does it need a whole load of work.
Picture below
Thanks in advance
I`m no expert, but if it`s below ground level I`d look at getting it tanked
I used damp proof cream,u can get kit with drills for single or double brick walls.Use it every 100 mm
That is for a horizontal DPC.
If the OP's wall has ground up against the external face, then he will need to do as Filo says above, or remove the ground
