I'm DIYing a U shaped kitchen. The walls are straight and flat and I've done the floor and cabinets. Now its come to fitting the worktop its clear that the walls aren't square. I have the worktop and its been professionally mitred.
The gap between worktop and wall is too big to caulk or cover with a splash back. Should I sand or maybe recess the wall so that the worktop will slide in? Or I could scribe the edge of the worktop and cut it to make it flush with the wall?
If I shove the worktop against the walls then it puts one of the joints out (see pic). Is it feasible to scribe and sand down this joint to make it fit?
View media item 46679
