whirlpool dishwasher ADP3550 hangs
24 Jun 2012
Hi
I have got this washer from a friend because his neighbour has trown it out.
I have tried to find the problem. I have tested it several times and it looks to work.
The last time it stopped at a certain position and I could hear the pump going and going. it is the one with a heating element built in.
Can anyone give me a tips?
If the drain pump runs continually then there is a leak someplace & the antiflood device has been activated.
Leaning the dishwasher back (or forward) will confirm it (have some old towels ready to soak up the water that will run out).
Now you know why it was thrown out :wink:
I can't see no leak
You won't see any leak either. The water is on the baseplate of the machine.
The antiflood (when activated) cuts the water supply, stops the program & activates the pump. Tip the machine forward & you'll see :roll:
When this fault occurs the start button LED should also flash twice in a repeating sequence until the machine is turned off.
Ok I will check this
