I had a leak in my rad of my mk3 golf which isoon fixed with some rad weld. Since then I had to refill the coolent obviously and this was near on empty. I filled it up with only water as I wanted to ensure I had fixed it before putting any coolent in the system. Since then it's reaching 110 degrees which is a lot more than before. I've checked both the upper and lower pipes on th rad and they are both hot, also the heater works fine. Is this simply that the system has only water in and once coolent is added it will be ok or am I slightly to optimistic?
