Hi all
I'am going to install some velux rooflights and a floor in the loft of my bungalow, can anyone advise as to the thickness of kingspan between the rafters which are 50x75mm.
Thanking you in advance
t75mm
t75mm
Thanks Dan as its a bungalow would they (Building Control) also require insulation in the new floor?
The real answers that you won't like are:Hi allI'am going to install some velux rooflights and a floor in the loft of my bungalow, can anyone advise as to the thickness of kingspan between the rafters which are 50x75mm.
SNM";p="2451232 said:What's this gotta do with plumbing ?[/quote
Your quite right SMN I'v posted in the wrong forum sorry!]
Why did you have to go and ruin it, I thought the fellas were doing quite wellWhat's this gotta do with plumbing ?![]()
I do like your reply! Why do'nt Building Regs state what is required rather than u/values with so many combinations?The real answers that you won't like are:Hi allI'am going to install some velux rooflights and a floor in the loft of my bungalow, can anyone advise as to the thickness of kingspan between the rafters which are 50x75mm.
A likely insulation thickness for the roof would be 150mm with a 50mm air gap above the insulation.
The floor will require substantial structural alterations before it can be used as a habitable room. Putting insulation in it is the least of your problems.
Despite what advertisements might imply, shoving a couple of Velux windows in your roof does not make a loft conversion.
Your right they are!!!!!!Why did you have to go and ruin it, I thought the fellas were doing quite wellWhat's this gotta do with plumbing ?![]()
