Ignoring the tit-for-tat pecks between posters and the OP; there are a few questions the posters might have asked which may be useful.
To the OP:_ Without querying your knowledge about Ohms (
, - are the figures correct? Are you building it yourself (I fancy doing that)?
That is one huge electric cycle. I've seen pictures of electric scramble bikes in the USA which may be high powered, but 1500W seems maximum in UK and most are below 1000W, with voltages up to 48. Once above 50V there start to be implications for electrical safety, so your voltage is much higher than expected.
Having said that - is this your aim? -http://www.youtube.com/watch?v=ZzvtY5TzqKQ
Why do you want 3 core flex? Normally for high currents such as you expect (as found in automotive applications) the cable is a single unit either a thick cable or a bar connector (one for positive, the other negative/earth. Relays are used to limit the amount of such thick cable.
Electric vehicles are a specialist area and I'm more interested than knowledgeable so your comments on my questions would be useful to me
