odometer stopped working
25 Jun 2012
I have a 1990 benz 190E with 100,000 miles and the odometer has stopped working. Is this something easy to repair and if so what is required.
Thank again.
Being made in 1990 it probably has a mechanical cable drive which I expect has broken.
Peter
You are quite correct, I didn't read the mail properly - again :oops: the speedo itself must be faulty.
Peter
The odometer functiln is controlled by the processor which is built into the cluster assembly. so you will need to replace your instrument cluster.
salvage car title
The odometer functiln is controlled by the processor which is built into the cluster assembly. so you will need to replace your instrument cluster. I get the impression this is pre-electronic
and relates to an analogue display, numbers around the edge of little wheel drums, advancing in sequence.
Wotan
salvage car title
