Hi all,
Having some issues again with the Vaillant Turbomax boiler which is now 11 years old.
When you open any hot water tap, the boiler seems to ignore the demand and remain off, if you press 'i' you get the code S.30. If you leave the tap open for a while it eventually comes on but only for a short period before switching off again, when it does come on, the water is nice and hot and at a constant temperature and when it goes off, the pump overrun will time out and the boiler will go back to S.30 (no heat demand)
The green light doesn't flash when hot water is being requested.
I checked that the heating is working and this works normally as it should.
Any ideas on what the problem is?
