Hope you guys can help me, I currently have an old manhole in my garden which only really acts as an inspection hatch and only has 1 inlet and 1 outlet on to the next manhole, I have been told I can remove it as it will be in the way of a new internal wall foundation. So my plan is to break it all out and replace the gulley in the manhole with a new length of plastic pipe that will run right through to the next manhole.
However Im a little concerned about how to connect to the existing clay pipe without causing a step or a ridge where poo could build up and cause a blockage
Can I cut a piece of plastic sewage pipe longways in half, place it over the existing gulley section to form a full pipe, seal it all up and then back fill it with Concrete??
Many Thanks
Many Thanks
