Trident Trance leaking
2 Sep 2012
Derbyshire
I've just fitted a replacement heater can assembly and the shower is now leaking from the outlet of the can, but only when the shower head is on. When the head is removed there is no leaking. Might this something to do with the PRD?
Possibly if water is leaking through the pressure relief device it
could be a couple of things causing it but it could well be the shower head is partially blocked or not suitable for the type of shower
Your going to need a new prd if you have lost the ball in the prd.
more likely never re-commissioned it properly after fitting the new can.
The water isn't coming from the prd - it's coming from the outlet join on the opposite side of the can.....
Sounds about right. Spent a long time doing the fiddly bits and then failed to read the re-commissioning instructions before turning water and power back on.
Is it coming from the join to the stabiliser valve on the side ? or the outlet seal ?
