Hi All,
Ive been reading a lot of topics on here about the Pumas 80e pressure problems and fixes. I just wanted to say whats going on with mine as i havent seen any similar posts.
When i was out at work my father was at my house and called to say there was no hot water i told him to check the boiler and he said the low pressure light was on, which maybe happened twice in the last 3 years, I told him its fine he just needed to re-pressureise it. But he done it far to much and i heard a horrible vibrating noise down the phone (which im guessing was the overflow pump?). Once it had stopped this after about 3-4mins i told him to switch it off and leave till i got home.
When i got home i bled the radiators and got the pressure back down to 1bar but over the week since i have had to repressure the boiler every 2nd day and when the heating is on the pressure goes way up to 3.5bar and cuts out then once the pressure comes down again it fires back up.
Has he busted my boiler or is it fixable?
I also noticed the PCB sparking in the top left corner when i switch the boiler back on at the wall (some times it doesn't switch on the first time), I noticed this was a common problem with the boiler as well, should i replace this board as well?
Thanks for any help,
Greig
Greig
