please help, I have a puma 80e that was not giving hot water, CH works fine, was told to fit a new wax capsule to DV, did this and it worked fine for a couple of weeks, Now the HW does not fire up at all, changed the PCB and water pressure switch but still the boiler is not firing when the hot tap is turned on. The LED on the pcb lights up, but no ignition so no hot water. can anyone help as i have spent hours on this forum looking but not found this problem.
thanks
nic
thanks
nic
