S
Soggy_weetabix
How can I check if the pump is faulty, i've checked and there is voltage ok to it. Is there anyway I can check it before replacing it with a new one.
Remove it and test it.
On FULL flame it would boil v quickly.
As the man says, sounds like Diverter, but could just be the pump messing about I suppose. Haven't seen either work in bursts
Look at the wax capsute located INSIDE the divertor.
To locate it, find the most difficult part to change. Go away, come back and realise its even more of a bit*h to change that you first thought. Then buy a wax capsule.
20 min job. No dripping taps I presume?
David
