Setup looks like this, and I need a feed to the hood.
What would be the ideal way to acheive this? (or how do you do it)
I'm thinking spur off the ring upto the isolator bring cable down then back up to a fcu hidden inside the chimney part (lots of cable) plus not so easy to change the fuse if needed and there's no space behind the oven for the fcu (also dont want to chase flex cable into the wall - I've not checked to see if the appliance can be rewired with standard t&e)
