Ive owned my 2001 Citroen Dispatch 2.0 hdi for around 3 years and it has been faultless.. until this problem..!
The van wasnt used for a few weeks, then one morning I went to start it and the battery had run flat so I used some jump leads in attempt to get it going.. however it just wouldnt go, just kept turning over..
So we towed the van to a mechanic.. he did some tests and said the glow plug relay wasnt working nor the pump in the fuel tank and something else.. so suspected an ECU fault..(maybe an immobilser inside the ecu or something)
The ECU was sent away to be checked and returned with no faults..!
Just wondering if anybody could suggest anything else left to check.. or has had the same issue?
Any help would be greatly appreciated!
