Afternoon all,
I am just after some re-assurance that I am doing things correct and would really appreciate some tips or advice if needed.
I live in a 3 story town house, fairly new build (6 years) with radiators in every room. We have an ideal ICOS condensing boiler (He12 I think) and basically ever since we have lived here, the living room radiator never gets red hot like the other radiators. It barely gets luke warm to be honest which is why I have finally decided to address it.
A boiler repair man a few years ago said it may have sludge in which needs flushing but it was only a couple of years old at the time and it has never worked properly so I put that off (really wish I had flushed it now tbh though). My friend said it is maybe the last radiator in the system and therefore not getting hot enough but he isnt a boiler man so he was just guessing.
So today I have finally decided to start investigating the problem. Google here I went. A video instructed to make sure the lock shield valve is fully open on the radiator that doesnt work and then go around and turn all of the other radiators off. If the radiator heats up then go around and turn each radiator on one by one and see what happens.
I have done this and noticed when I went around checking the radiators that all of the "lock shield valves" were open apart from 1.
First question would be, should i open or close all of the lock shield valves during this test? They are all open at the moment but I am thinking they should be closed for this?
Second question is am I on the right lines? I am thinking that if the radiator does heat up that I should go about balancing the other radiators. If the radiator doesnt heat up, then its the radiator?
Thanks in advance. I will say all radiators have been bled. I will let you know if the cold radiator starts to heat up over the next hour or so
