Last week I had my whole kitchen taken back to the brickwork, sand and cemented, bonded and plastered. Nothing painted yet. Where part of an old chimney breast on the inside wall was removed and old artex and plaster taken back to the bricks, it exposed a vertical copper pipe which feeds cold water to the flat above me. The new plasterwork in front of the pipe is now showing what appears to be signs of degradation right along the line of the pipe due to cold. It's not leaking, just cold. The wall actually feels colder if I run my hand along the line of the pipe which is visible in my pictures, but either side of it, the plaster isn't cold. Near the bottom of the wall (new skirting boards have not been done yet) you can see dark patches. The upper dark patch (which I've done a close up of) is rough to the touch compared to the rest of the plasterwork. What can I do to stop it getting worse?, assuming this isn't still plasterwork drying out, which I don't think it is. Damp block was mentioned to me, would coating the plaster with that help to seal it, or any other product? I'd rather not paint the walls till it's fixed. Central heating has just been installed in my flat and I've kept the kitchen rad on pretty much 24/7. Also, there is a new 6" extractor fan installed though not operational for a couple more days or so. Presumably the fan plus central heating should help to minimise cold damage. The last picture isn't as bad as it looks, it's a patch of white filler for some plaster that chipped, and some other stuff stuck to the plaster.
