Hi
Just had a new Vaillant 418 installed to replace a Ideal minimiser ff30 which has a 10KW output
Was going to go for the 415 but was advised to go for the 418 by 2 different companies - so took the advise
My monthly gas bill used to be about £35-50 per month with the old boiler
Have monitored a few days usage & it will result in a bill of about £80.00 approx
After reading quite a few forum posts - understood that the boiler can be rated down with D0 setting
After checking the total heating requirement the boiler - I really should have gone for the 415 which would have been more than enough -oh well lesson learned
Hall way rad is switched off so this equates to about 6 KW + 2KW for the HW
The boiler wasn't changed from the default settings by the installer
The rad water temp was set by the installer to 73°C this was very uncomfortable heat
So I dropped it to 58°C which was much better
Property is a 2 bed end terrace built in 1997
Back bedroom 3364 btu/h
top of stairs 1047 btu/h
bathroom 1365 btu/h
front bedroom 2883 btu/h
lounge rad 1 4852 btu/h
lounge rad 2 2426 btu/h
hallway 1365 btu/h
Kitchen 2426 btu/h
toilet 1047 btu/h
20775 total
I'm now trying to get the boiler to the most efficient settings
Last night I set D0 to 10 would you recommend going any lower
The boiler is now firing for longer which I believe is better?
Are there any other setting I need to change
Thanks in advance
Dave
bathroom 1365 btu/h
hallway 1365 btu/h
Kitchen 2426 btu/h
toilet 1047 btu/h
20775 total
Thanks in advance
Dave
