I would be grateful for any assistance possible with the following problem I have with my Potterton Profile 50e boiler and associated controls.
The system appears to be fully operational when the programmer is calling for hot water, but if calling for heating, nothing happens.
I have changed out the programmer, thermostat and 3port zone valve head for new items, (now running with Horstman Centaur 7 & C27 stat and programmer respectively, and new salus 3pt zone valve head).
Prior to the change of the valve head the valve was defaulting to DHW only, now at least the valve is operating as it should, but boiler will not start up unless the hot water is calling.
Is there anything I have missed or is there a component in the boiler itself which may be causing this fault.
Thanks in advance
Thanks in advance
