Oil feed service tap/valve
16 Nov 2012
Bedfordshire
Hi, can someone point me in the direction of a suitable tap/valve for 10mm oil feed to my boiler.
Its to go at the boiler end rather than tank end if it makes any odds.
I can find plenty that are Gas/Water rated, but none that are oil.
many thanks
Gas rated lever ball valve will br fine, or you can use one of the fusible head valves available from BES
Fusible oil valves CAN be used as an isolating valve, but have to be treated with kid gloves because of the fragility of the fusible insert.
