Just a quick question, Just having a extension done with a new kitchen and two new en-suites.
For our hot water we have a new modern combi boiler, what as usual takes 15mm cold water in and 15mm hot water out.
The plummer has used 15mm pipe for all the hot and the cold water pipes, is this normal?
Would it not be best to use 22mm for all the cold water pipes, or at least until the pipe splits for the hot and the cold water supply's/circuits?
Just a bit worried the flow rate of the hot water being affected while the washing machine is on or the toilet cistern filling up for example.
Advice much appreciated.
