Noise from wall...
11 Feb 2013
Manchester
Hi I am new to the site so sorry if i have asked the question in the incorrect place as this could be an electrical or plastering question due to the work that has taken place.
Basically i used to have an electric fire on the wall, i have removed the fire and where i had the fused switch i have placed a 30amp junction from here i have run a 2.5mm twin and earth down the cavity feeding two fused switches. This is to supply me TV and Sky box now wall mounted.
I have placed all cables (HDMI / satellite etc) in a channel in the wall everything was exposed for a week but in full use whilst i waited on the plasterer coming, no problems...
On saturday the plastering was completed and it looks great, on Sunday afternoon when the plaster was looking dryer (It had gone very dark then a,lmost pale like skin colour) i rehung the TV and shelf. All afternoon everything was great...
21:00 last night a rather loud noise which sounded like a loud crack came from the wall. This is no where near where my electrics or shelf and tv have been hung, it was approximately 2.4 meters from that work. The noise was like a crack noise or snap noise. It is difficult to describe. Then 30 minutes later the same noise from the other end of the room. It has done this approximately 5/6 times now which is worry ing however i cannot workout what it is.
The wall itself is the dividing wall of a semi detached. The wall i think is thermalite block with dot and dab platser board which appears to be approximately an inch think. This had previously been plastered which i have had reskimmed.
Any ideas what the noise could be? Any comments would help even if you quote you dont know and that what i have done sounds sound.
Impossible to say about the noise. But I have some comments on the other items from your post.
I hope that this junction box is accessible. It must not be covered over/ plastered in.
Also, was the original fused switch a part of the ring (eg two feed cables) or was it a spur (probably with only one cable). If the latter then you cannot add more sockets without a load-limiting fuse.
I do hope that the data (HDMI etc) cables do not share the same chase as the mains voltage cables. There should be a separation of at least 50mm between them.
Junction access is available.
It was already a spur, i will look into adding a load limiting fuse thank you for advice.
Chase for mains and HDMI are 450mm apart.
Can you clarify the term Load limiting fuse? I have added two fuse switches not sockets.. Is this what you mean or are you meaning something else? Your advice is greatly recieved.
If i replace the Junction with a load limiting fused switch, would this satisfy regulation?
Yes put a fused connection unit where the joint box is. Have the original wire as the feed in and the new one to your two fused switches as the load. This should then be ok, but your limited to the 13a max load of the fuse.
Thats an easy solution. Thank you..
Still not solved the noise problem in the wall though. :(
I am going to carry that out at the weekend, as an aside if the cable is pulling too much (Greater than 13amp) although i doubt it with a sky box and TV. Would that cause the noises we heard? I would assume it would trip my consumer unit...
TV and SKY box wont be more than a couple of amps.
I guess you're not missing anything around the house? Dog, cat, hamster, wife?
What happened to the plasterer? :lol:
Plasterer has been out to take a look. We have hair line cracks at every board joint. The joints match the number of loud noises we heard thus must have been the fresh plaster cracking/ snapping. Upon further investigation the joints when the house had been built had not been taped. When the wall was exposed to the damp of the wet plaster the drying process caused the cracks. Or so we think...
