I'm wanting to make a hot wire cutter to use with foam/styrofoam for model making etc. Does anyone here have knowledge of making one of these.
I was thinking after doing some research of using a mobile phone charger (or similar) that provided a 12v 2-3amp DC output and connecting the 'hot wire' to that to provide the basic function. Would I also be able to regulate to amps to the wire and intern lower/higher the heat output if needed and what about light to signify that the device was switched on.
I would idealy like to create something similar to this
View media item 56786
Any advice/opinions would be gratefully received
I know it's not technically household electrics but as it will be run from a mains socket I thought it would be best to post it here
Cheers folks
Cheers folks
