1 Box 2 circuits
21 Nov 2010
I always understood that there should never be more than one circuit in a box with 2 or more gang switches. IE all should be fed from one circuit.
Is this the case with current regulations?
It is good practise to leave a note where irt can be seen ( on the CU if not adjacent to the box concerned ) to make it clear that more than one isolator needs to be operated to remove all live supplies from the box.
I have seen paper notes about dual feeds folded behind switches, Not sure that is a good idea as it maybe a fire risk.
And think about kitchen grid switches with lighting, socket and oven switches all in one box.
Thanks everyone for the response.
I am having new CU's installed and one lighting circuit feeds half the house and many outside lights so I wanted to split it so the outside lights are on a separate circuit. The only way to split it without major rewiring results in the 2 gang switch in the entrance porch having a switch on each circuit. I have always avoided 2 circuits in 1 box before, making sure the hall stairs and landing were all on the same circuit but I now know I can do it in this instance.
Thanks again.
Those would be best on their own DP RCBO - did the electrician not suggest that?
Better if they are not, because then if you lose one circuit you can still get some light on the stairs.
I am having RCBO's put on every circuit although they are the normal single pole ones. Seems like sense to me while changing CU. Much less of a problem through nuisance tripping (due to bulbs blowing etc) and much easier fault finding in event of a problem.
