2 Gang Pattress Box with 2 x 1 Gang Chrome Switches
3 Mar 2012
Surrey
Hi everyone,
I have a new home and have recently installed two chandeliers in my lounge which are both on separate circuits. There is also a third circuit for 4 spot lights. All three circuits currently return to a 1 Gang 3 switch chrome plate. I want to be able to dim the chandeliers. The spot lights are not dimmable. I do not want 2 separate 1 Gang pattress boxes and would ideally like one 2 gang pattress box which takes two 1 gang CHROME plated switches (one with a 2 switch dimmer and the other a single chrome switch for the spotlights). Is this possible? I'm concerned with a standard 2 gang pattress box the 2 chrome switch plates will be too large for the one box.
Many thanks in advance.
Chris
I can't understand your question. I think you think the number of gangs is something other than what it is. Basically it is the number of switches, so when you say "1 Gang 3 switch chrome plate" it just doesn't make sense to me.
The best I can come up with is that you refer to a standard width plate as a 1 gang, and a double with plate (same width as a double socket) as a 2 gang, but even then I cant work out exactly what you are asking.
One suggestion that might help is that you can get switches which look like dimmer modules but aren't, so you could get a 2 or 3 gang dimmer and change one or more modules for one of these 'pretend dimmer' switches.
Are you restricted by width or is it just looks you are concerned about.
Look at grid switches or put two single gangs together
Very often the decorative switches (in this instance the chrome ones) are slightly larger than the standard and they can be a problem to get side by side on a dual pattress/back box.
pj
