A friend has had the kitchen walls skimmed - they were a bit rough to start with, then we set about chasing out electrics etc
Anyway, quite predictably, when we ripped the old kitchen out, behind some of the units there was damp - which my mate treated with bleach (that was a few months ago). 1960s bungalow, block walls ('kin hard block at that), the inner leaf blocks have what looks like PU foam insulation on the back, no cavity insulation (yet).
Now the wall has been skimmed (this one is near enough external, it backs onto the garage), it looks like the mould has come through.
Is this the problem or something else ?
Should he be worried about it ?
Should he do anything, and if so, what ?
These photos were taken about 5 days after this wall was skimmed. The other 3 walls were skimmed about a week earlier.
There's a few damp patches which are where holes* were filled (binding?) before being skimmed over. Apart from that, the blotchiness is obvious.
* Eg, there used to be a single socket below the new double backbox, to the right of the drain pipe. Also, you can see where the old cooker connection was, and the diagonal cable run up to the switch.
