That should be OK.Circulating pumps CP63. previously mysonWhich pump do you have?
The high (25C) differential suggests two things:
1. The head (internal resistance) of the system is very high, or
2. The pump is faulty and not circulating the water fast enough.
When all valves are fully open the system resistance is at its minimum, which would discount the first - unless there was a system design flaw. So we are left with option two.
However, a third possibility is that the valves either side of the pump are not fully open. (Be careful when trying them, particularly if they are stiff; you don't want to break the shaft!)
