I am first time poster to these forums and am hoping for some advice for the central heating system of the house we moved into in August. I have had a heating engineer round who has resolved some of the issues we had, but the thermal cut off switch on the underside of the boiler continues to trip on a regular basis.
System comprises Glow Worm Fuel Saver 80F boiler in the kitchen, hot water tank in the upstairs airing cupboard and cold water supply tank in the loft (2 tanks, the smaller one I believe feeds the CH system?). System does not have a room thermostat and relies on boiler thermostat and TRVs on all radiators. The radiators and the hot water tank all work very efficiently assuming the boiler is operating.
The following summarises all the issues which we had:
1 - Boiler still firing up after the timer unit supposedly had switched it off.
2- The burner taking up to several minutes to light after the system being switched on (although the fan operated).
3 - Occasional loud banging coming from the boiler like a bag of bolts had been tipped into it (usually some hours into operation).
4 - Occasional tripping of the thermal cut off switch – usually after a couple of hours of operation and often accompanying the banging noises.
The heating engineer has:
1 - Tightened the casing – burner now operates quickly.
2 - Increased pump speed – seems to have cured worst of the banging noises.
3 - Replaced the timer unit – made no difference.
4 - Replaced boiler circuit board – system now turns off correctly when prompted by the timer unit.
5 - Replaced thermostat on front of boiler.
6 - Partially opened valve (in airing cupboard) to a separate circuit from the CH and HW circuits - not sure what this was about??
Whilst 3 of our 4 issues have been resolved, the thermal cut off switch is still tripping and on a more regular basis than before. I don’t know if this is a reaction to the work already done or a symptom of the recent cold weather. I am currently re-setting the cut off switch around 4 times between 4pm and 10pm.
Provided we keep re-setting the switch we have a functioning CH and HW system which is very effective, but it’s annoying and I would be concerned about what should happen if the thermal cut off switch was to fail (can this happen?). In the future we will probably have the boiler replaced with something more efficient but, in the meantime, if anyone has experienced similar issues with this boiler and was able to cure it, I would be grateful for your advice.
