I have had a 5 month saga with an intermittent problem that my local plumber has given up on. It's a system about 18yrs old with Glow-worm Fuelsaver 80F boiler which works fine when the central heating is running but if the hot water is running by itself there is occasionally a banging noise in the boiler and the thermal trip operates. The pipework from the boiler to the cylinder has been relaid (because it was thought to be blocked around a compression fitting - not true in the event). The whole hot water path has been flushed - perhaps a minor improvement. The system will run for a couple of weeks OK then crash off once every day for a few days then carry on OK. I notice that the Honeywell mid position divertor valve is allowing some heat to transfer to the CH pipework when on HW only - too hot to touch 2ft from the valve. Is there any experience of these valves sticking and perhaps reducing the flow? With the warmer weather approaching the CH will be off and the problem can only get worse.
Any suggestions would be gratefully received.
