Push toilet overrun
10 Jan 2004
Hi Guys,
I ve had a B&Q toilet for a while now, say at least 5 months. I've noticed that over the last few weeks it's starting to take longer and longer to stop after a flush. It over runs down the centre flush tube.
At the left hand side where the water come in I have a tube with an attachment with a grey screw. This was the setting to stop the over run just before the water reached the top of the pipe. No mater what setting I screw to it over runs for about 3 mins before stopping.
It's not the ball float system
Any ideas?
Water overflowing after a flush "not the ball float system".
Says who?
That's what lets water in, that's what stops the water coming in. It's not doing the latter when it should be, by the sounds of it.
Says who?
I think he means that it isnt the old ball float system that he has but the newer inlet valves that dont have the ball float,
A picture says a thousand words.
It could have debris on the washer. Did it come with any instructions for flushing through?
If you lift the cistern lid, there's a blue plastic type slider inside a tube - lay mans terms. You will prob find it's sticking, and staying up, and allowing water to be dumped straight in the pan. Like Charnwood said, check for debris, I sorted my bros by spraying some silicone spray over the plastic surfaces.
