This isn't strictly electrics but you guys will know the answer!
I am trying to run some CAT5e above a suspended ceiling (15m run). I was going down the route of catenary wire, attaching eyebolts at each end and supporting wires along the length attached to the concrete ceiling. There are several H beams running across my path and I figured it would be much easier if I could directly clamp / clip onto these beams to attach the catenary wire.
I also have a couple of other runs to do that could clip directly to the beam all the way along. Again, I just need some way to suspend something off of the beam.
I assume something to do this exists but can't work out what or where to get it. I found H beam clamps which are a C shape and have a bolt running through it but there doesn't seem to be anywhere to attach anything to it!
Can someone recommend the best course of action here?
Graham
Graham
