Hello
I hope someone could kindly give me some advice.
I have a small U shaped kitchen, where the gas hob is located, to the left is a cooker socket with a cooker plate behind the cabinet the hob is fitted to. Nothing is using the cooker connection.
I have bought a new oven which the manufacturer has stated can be connected either to a 13amp fused plug or fused spur both via 2.5mm BUTYL flex or to a cooker plate using 2.5mm TE.
The oven will not be going under the gas hob but to the right in a oven housing unit. The distance from cooker on and off socket to the oven on and off socket is 1.7m point to point.
My questions are how long can the 2.5mm TE cable be from the cooker connection plate to the oven?
Can the cable run behind the kitchen cabinets along the floor which will have plinths covering the fronts or does it need to be put in trunking?
If the above is ok when the cable enters the oven housing unit can it connect directly to the oven with a certain amount of extra cable so the oven can be pulled out for maintenance or does it need connect to another connection plate then the cooker ?
The alternative i was thinking was to use a single 13amp socket which is available 30cm to the left of the oven housing unit and convert it to a 13amp FCU. Would it be ok to chase some of the wall put some plastic electrical trunking to the FCU which would lead out behind the oven and then feed the 2.5mm BUTYL cable into the trunking? or do i need to use some sort of connection plate in the oven housing?
I have attached a technical birds eye view picture of my kitchen in my album not sure how to attach to post
Here is a link
https://www.dropbox.com/s/crypcnhub7f82qi/KitchenMod.jpg?m
Thanks for your time
Here is a link
