I want to install a new single electric oven and gas hob(with electric ignition). I have a 32 amp fuse in the consumer unit with 6mill twin and earth running to a dp cooker connecting switch with a 13amp socket built in and then onto a cooker connecting unit behind where the oven goes. Both the oven and hob come with a plug rated at 13amps attached, the oven is 2400kwh. Is it safe to change the cooker connecting unit to a standard double socket outlet so i can just plug both in. does the 6mill cable mean there will be to much current going into the socket?
