Aeration is the job to help heavily trafficked areas such as a commonly used route to the shed etc. You can do this by hand over a small area or hire a corer for larger lawns.
This would need to be combined with a feed and over seed as stated above
Exactly what just been said. Hollow coring is the way to go. Compaction will encourage weeds like plantago major, moss etc as the drainage becomes poor. If possible, dont cut the affected area as much to let the grass leaf grow or if cutting is a must, raise the hight of your cut.
