Yes the cable is the same as used in other circuits. Would a 13amp switch suffice?Assuming that the cable to the alarm is appropriate (similar to that in the lighting circuit), you would not need a fused connection unit to connect it to the lighting circuit. Just a double-pole switch (easily found) would be adequate.
I can fully understand the reasoning behind this, but I guess I have to persuade myself to make the decision.It's obviously your decision but, as I said before a switch in the loft is hardly worth having. If something goes wrong with the alarms and trips the lighting breaker (at nightime, of course!), I can't imagine it would be much fun trying to get into the loft to operate the switch so that you could get your lights back on! As Iggifer and I have said, a switch high up on a wall is not very intrusive, and ought to be easily connected to things in the loft.
Thanks to all you guys for your help and advice. I will carry out the work this weekend and update you on it.
