Plumbing & Drainage Pipe work woes
5 Nov 2008
London
Hi All,
I am looking for simple stuff... all solvent weld pipework none of this push fit stuff
100mm 92.5 degree branch in white
50mm reducer that will fit inside the 100mm pipe
50mm pipe in white
100mm pipe in white
100mm end cap
the solvent pipework must be flat on the outside like this:
LL
happy to adjust the figures to 110mm etc if needed...
I've tried, homebase, b&q, plumbase, screwfix, travis, and the like...
thanks in advance all!!
im pretty sure by the pictures that you are using push-fit fittings.
Also solvent weld cant be used outside.
I can find the parts in the USA but not here in the UK
it's SCH40 pipe work also....
Polypipe Terrain do 110 white solvent 92.5 T.
Easy to find.
If you're putting 32-50mm waste pipe into the T's branch you might be better with a 110 straight coupler with a boss.
Plumbing section might have been a better place for the query.......
Easy to find.
can't find it, tried the first page of google no sites sell a solvent white version....
I found something similar but one site wanted £60 for something that should really only cost £8...
