I need to install 3 check valves (isolation Valves/needle valves) to enable me to isolate a sink and toilet cold water feed.
I think the pipes are probably .5 inch as the house was built in about 1965 and these are original pipes.
I was hoping to pich up a pack of 10 valves from screwfix or similar but they are all 15mm.
I have seen people talking about using 15mm fitting on .5 ich pipe but I am worried that the olives wont fit on the slightly larger .5 inch pipe.
Is it possible to get .5 inch olives and use them in 15mm fittings? If so is this recommended or is there a better solution?
Thanks[code:1][/code:1]
