Ok, so you want to exchange your thermal store for an unvented cylinder.
How do you expect to get 30lpm+ from it?
How big do you think the cylinder will need to be to service the 30lpm+ showerhead?
What head of water do you have?
Are you thinking of fitting a pump?
Why do you feel the need for a 30lpm+ showerhead?
Thank you
Firstly I'm not definitely saying I'll get a 30l/min shower. That comment was in response to Tony saying I could get shower heads even less than 15l/min.
What I would really like to do is run two 15l/min showers at the same time very easily, and perhaps even run a sink etc without any drop off in performance
[/b]How do you expect to get 30lpm+ from it?[/b]
I'm not sure what you mean. The cylinder will be supplying hot water only at a usual 60:40 ratio so will need to to supply 0.6x30 =18l/min.
Apologies if I have misunderstood
If I understand correctly you mean the volume of water I'd need to provide the hot water. A 300litre cylinder will run a 30l/min output (ie 18l/min hot water) for 300/18 = 16 minutes. This sounds reasonable though I'm even happy to have two unvented cylinders if needed.
[/b]
Do you mean the pressure of my mains? It is at least 6 bar.
In terms of having a pump, well that's exactly the point. I'm trying to figure out if I spend the £4k will the flow increase enough such that I don't need break tanks, accumulators to store cold water and pumps to push the water around.
And finally I do take on board you comments about preserving resources, I do my bit in many other ways
Thanks for your help
