Vaillant Ecotec S.07 code
30 Jul 2013
Manchester
Hi All
I just moved into my new property
And found a problem with the Ecotec boiler.
HW works fine. But he central heating keeps going into cycles of the below:
1) burner starts and stays on few minutes
2) radiators that are close start getting warm. Ones further away has no change.
3) burner stops radiator logo flashing and pressing the info button it produces s.07
If I hit reset then the burner could come on for a few seconds before shutting down to s.07
If I leave it as is, the burner switches itself back on after a while an follows the above steps over and over again.
I have had a plumber release the air from all radiators and the boiler as well as flushing the system manually without using a jet.
Any ideas what could be causing this as the radiators never end up getting hot before it gets shut down.
Could also need the setting of d0 lowered to better suit the property.
Perhaps set d0 to the number of rads that you have using the +/- buttons and then save by pressing the "i" button.
Tony
HI
Sorry my boiler is actually a vaillant ecotec plus 418.
How do i check for D40 + D41?
I akready ran a P0 to ensure everything is bled properly.
I also used a hosepipe to do an extra push from the header tank today and opened up the ext exit pipes. Still no luck.
Have these plumbers been round or just told you this over the phone?
Over the phone.
My first plumber that came round to do work left saying "I dont know what else to do". thats after a power flush, full cleanout and a lot of work. And he even called valliant support team for help
Hmme.....
Perhaps he was not a boiler engineer?
Probably just a plumber?
Tony
Wiring fault or plumber may have tempered with fan speed (dependant on skill) and turned it up instead of down. Fan speed settings are back to front, up is down, down is up. I had a vaillant engineer do this to me.
IMO respectively.
I'd be looking at the pump first off. Check if the impeller is clear of debris and it is set to its highest speed.
