Hi All
I just moved into my new property
And found a problem with the Ecotec boiler.
HW works fine. But he central heating keeps going into cycles of the below:
1) burner starts and stays on few minutes
2) radiators that are close start getting warm. Ones further away has no change.
3) burner stops radiator logo flashing and pressing the info button it produces s.07
If I hit reset then the burner could come on for a few seconds before shutting down to s.07
If I leave it as is, the burner switches itself back on after a while an follows the above steps over and over again.
I have had a plumber release the air from all radiators and the boiler as well as flushing the system manually without using a jet.
Any ideas what could be causing this as the radiators never end up getting hot before it gets shut down.
