So the question is....... is that a live and neutral coming down to the wall terminal block or is it live and switch live?
Only testing will tell - have you done it yet?
Then as I have added double check the terminals are not pinching the blue/brown insulators.
Out of interest what was you ohm reading?
How do you know this????So the question is....... is that a live and neutral coming down to the wall terminal block or is it live and switch live?
On the right hand side of the wall? I've tested that and it's a live and a switched live
How did you conduct the continuity test I suggested if your multi-meter is at your aunties and you don't currently have access to it?
How did you test that the red conductors at the light? - Please don't say with a test screwdriver!
It is difficult enough to try and work out what is wrong with your installation from afar without you giving us misleading information.
The 'pinching' of the terminal block terminals is the one connected to the switch by the way - not the one at the lamp.
