Extension
  • Thread starter Thread starter Yo
  • Start date Start date
Yo
21 Aug 2013
London
I am about to do the brick laying for the extension i intended. As i have a tight budget i am planning to do it myself. I took a brick laying couse. The one thing that confuses me is DPC. I know i need to put one atleast 150mm above ground level and in all openings, like window and doors. The one thing i am not sure is do i need to put DPC where the new building joins the old brick work.The new walls to be tied to existing using Furfix profiles.. Help please???
No.
However, you would need to have measures in place to prevent the spread of damp from a building that has no dpc to a building that does.
Vertical dpc is only needed if jambs are built as solid abutments. Solid abutments are acceptable for aerated blocks only.
Otherwise leave the cavity open and use proprietary cavity closers or use my own preferred method.
which is?
Take a 100mm sheet of foil sandwich celotex and cut it into 100 mm strips. Fit this into the cavity, (foil sides facing the masonry) using celotex wedges where necessary, then foam all the gaps.
You can not budge the stuff unlike poxy cav' clodgers that move and wander about the second you try and dab any boards onto them. Total waz. Mine you can punch as hard as you like and won't budge, won't bridge damp and won't bridge cold.
Do you use that method to close off the cills too?
Where the cavity remains open at head height, eg. where a stone head & concrete lintel are used, do you do the same. A poor detail on many new builds, I've noticed.
