I'm finally giving in and asking for help on this.
I have a Honeywell T6360B - fairly common from the amount of reading I've done. Main source of advice was here;
http://www.dancingfrog.co.uk/posts/2013-08-24-honeywell-t6360b-thermostat-wiring
and this is a pic of my T6360B
1 - Live (Yellow)
2 - Neutral (Blue)
3 - Switched Live (Red)
The Salus RT200 has a nice backplate with good markings.
the problem;
When I wire up the back plate nothing happens. No call for heat, no light. The current programmer is an old Honeywell ST699 - due to be replaced with Salus EP200 after this is sorted.
I checked the control box, and it's not wired up like the Y plan in all the diagrams..
So the existing room stat is wired -
Live (Yellow) to 4 which is on an unknown cable.. goes down into the room with the boiler and the programmer.
Neutral (Blue) to 2 which looks like commons.
Switched Live (Red) to 5 which is connected to the white wire of the Valve.
So my question is, why does the old stat work and the new one doesn't when it's the same three wires?
The diagram I have says 1 should be the mains Live, so I guess the boiler is powered directly. There is an FCU in the wall, when I trip it the boiler shuts down.
Can anyone can offer some advice to get this working please?
I hope this is enough info to get started?
1 - Live (Yellow)
2 - Neutral (Blue)
the problem;
