Diy teething problems...
Hi, I added a new radiator to the system on the ground floor. I:
Drained the system
Cut into the hot and cold pipes running away from an existing rad
Connected them up to the new rad
Connected the new pipes back to the existing pipes under the floor
However, when turning the boiler back on (combi) the new rad, and one i took the feed from aren't getting hot at all, however the other 2 rads on the same floor (as well as the upstairs ones) are all working.
fyi there are no leaks at all, just 2 cold rads!
Any suggestions for the cause would be appreciated
Drained the system
