I'll try to keep this simple
I want to wire a Horstmann Electrisaver into the Honeywell Sundial Plan Wiring Centre to boost the central heating.
I understand the Honeywell wiring centre connections and what does what etc at that end
The new Horstmann switch instructions are here: http://www.horstmann.co.uk/download...ing/Electrisaver-UserandInstallationGuide.pdf
It states it requires separate connections as follows:
Neutral in
Neutral out
Live in
Live out
Earth in
Earth out
I recognise that if this was being used for an immersion tank application all those would be necessary and should be used.
However, because of the location the new switch is going and the fact that it is being wired into the wiring centre, is it actually necessary to wire it using 6 different connections?
For example, could I just wire it as switch with a neutral and earth from other cables (frost stat with live and supply for boiler) that comes from the wiring centre? I'd like to fit the new switch between the wiring centre and the boiler - fortunately this is where the boiler controls go so I'd like to utilise them if possible. I can't easily add new cables to where I want the switch to go.
Hopefully that makes sense.
Thanks in advance.
Neutral in
Neutral out
Live in
Live out
Earth in
Earth out
Thanks in advance.
